Slide along curve ( object)
Like a bead that would travel on a rigid wire. It stays perpendicular and moves in any direction along a curve , be it straight or curved. Such as a slide motion. Is there such a critter of a way? Thanks again. Maybe it would be something like a dynamic move. Dunno
_OrientOnCrv
you’ll probably have to experiment with it a bit to realize which way the objects need to be situated prior to calling the command in order to get proper placement… but this command will do what you’re asking for.
I worked with it and found out a out the placement part. Will have to get used to that. Thank you for the help
