Is there a command that lets you slide an object along a curve? Rotate works only if the curve is a perfect circle…
Try OrientOnCrv. I’d also use Grasshopper for this if you wanted to move the object and rotate or scale in unison, let me know if you want a sample definition, it should be super simple.
Just to give you some hope, V6 OrientOnCrv will do this…
Ahhhh that’s just the opiates talking
Brian I am very new to GH. So would appreciate a sample def. Thanks!
