I have to “flat” from 3D to 2D.
The problem is that I need flat it without changing the original dimensions. For example the “flatten” command of Autocad in not good because doesn’t save the original measures.
The final result should be something like in this imagine:
what do you mean by changing the original measurements? that it remains proportional correct?
or just squashed down parallel with the exact 2d boundaries? try ProjectToCPlane and click on the view you want to have it “flattened” to. that will give you a parallel projection without changing the boundaries
A section of an ellipsoid in “not developable” which means it can not be flattened with stretching and or shrinking.
Rhino for Windows has two commands for flattening non-developable surfaces, Smash and Squish. I don’t know what is currently available in Rhino for Mac.
Smash is the older command and does not have any options for how the surface is flattened.
Squish has options for how the surface is flattened, including attempting to preserve edge lengths.
Again, I don’t know what commands are available in Rhino for Mac.
Squish is likely the better bet. Smash will for sure give very incorrect results - see the command line for a report of the area difference from Smash - it will be large.
Thank you very much guys!
I’m working with Squish Command. Doing several setting.
I write you when I find the best option.
Thank you again and keep warm!
