Hello ,
I try create a Skin, I am following this steps:
For some reason i’m not getting it, can you make a print of register? I think I’m doing something wrong with the registry.
Thanks
Hello ,
Thanks
Hi @MatrixRatrix,
Remember, you need two things: the additions to the Registry and the shortcut which passes your scheme name to Rhino on the command line.
– Dale
Thank you @dale,
Yes I know that, but I set the two Registry and shortcut, and the test dont work, I suspect that is the
Registry, can you make me a print screen of the Registry tree?
Thanks
Here is a text dump of the key.
Key Name: HKEY_LOCAL_MACHINE\SOFTWARE\McNeel\Rhinoceros\6.0\Scheme: MySkin
Class Name: <NO CLASS>
Last Write Time: 9/20/2019 - 9:30 AM
Value 0
Type: REG_SZ
Data: C:\dev\github\mcneel\rhino-developer-samples\rhinocommon\cs\bin\SampleCsSkin.rhs
– Dale
Hello @dale,
I have some time stop, and I try the Skin test again, and right now the test sample is working as it should.
Now I have a little doubt, I want to create a very simple minimalist rhino, and using
the Skin I have to change the “Registry Key” and create a ShortCut with Rhino Skin specification.
But I need to create an installer that does this automatically when running the executable, that is, a shortcut with the changed path and the registry key, I have no idea how to do this, any tips ??
Thanks
