I’m running into an error where my curves are being simplified when I go to export them to my cutting software.
Normally I run my geometry through a nesting software after they’re created in rhino and then import to my cutting software- without any problems.
Recently I had created a quick outline that I tried to import straight to my cutting software from rhino and it straightened out all of my curves.
This was the original file:
Tape Holder.dxf (161.8 KB)
And then this is how it looked in my cutting software.
I tried running the same file through my nesting software, just to see what would happen, and that version imported correctly to the cutting software.
Tape Holder Nested.dxf (23.2 KB)
These are my export settings;
Any idea what could be causing the issue?
