Simpler Mesh from Brep
Hi All,
I’m having problems getting a representative mesh for some geometry a client sent me.
I’ve attached a sample object in the form of a grasshopper script (rhino6 but you can also open in rhino5 and get the same result).
If I nominate an edge tolerance of 5, I would like to achieve a mesh with a smaller number of faces and vertex.
Any suggestions on how to achieve this (ideally without having to rebuild the brep)? Generally this nomination has worked well in the past.
Thanks,
Jon
181013 meshing brep.gh (337.8 KB)
Did you try changing Min Edge Setting? Not sure what type of deviation that introduces, but it certainly reduces the face/vertex count.
Thanks, guess I should have thought of that. Think this will allow me to get the result I want.
