There’s probably a simple way to do this, but I’m not seeing it.
I’m trying to use Closest Point to draw a line between the closest points in a list of points. I’ve used Closest Point before without trouble, but this time is slightly different: the Point to search from and the Cloud of points to search are all in a single list, and I want to repeat this operation for every point in the list.
Currently Closest Point returns the same point as the closest so all my lines are 0 width.
In abstract, I understand that I need to create a list that contains nested lists containing every point except the one I’m comparing. I could probably stumble my way through it, but it feels like there should be an easy way to do this.
I’ve attached a minimal example of what I’m talking about. Appreciate any help you can provide.
Side question: What does Closest Point do when two points are exactly the same distance (as in my example)?Closest point debug.gh (10.8 KB)
