Connecting nearest Point in different 2 lists
Hi, Im pretty new to grasshopper and im sure this is a fairly simple problem,
I try to connect each point of List 1 to the neareast point in List 2, i thought i found a solution with ClosestPoints, but it doesnt get me the result i hoped for.
Is there a simple way to do this?
Im sorry for the horrible files
Thanks!
NachDurchhang.gh (11.2 KB)
TriHexalNachDurchhang.3dm (12.9 MB)
Flatten the C input of the Closest Point component. Does that look right?
Thank you for the Answer, it works perfect with the closestPont tool, only problem is that i want to connect the 3 nearest points and if i use the closestPointS tool and put the same inputs there i get a complete mess again.
Any Idea w
hy it is like that?
Thank You for the help
Like this?
NachDurchhang.gh (16.2 KB)
YES! Thank you so much, im still trying to understand why the graft is necessery, but it works just fine.
You really helped me out a lot here thank you!
I’d suggest reading the modelab primer it has good examples.
https://modelab.gitbooks.io/grasshopper-primer/content/1-foundations/1-5/0_designing-with-data-trees.html
