Select closest points from a given list
I am wondering if it is possible to divide a list of points into sublists, where points are sorted into the sublists by distance between them.
For example I have this list of random points:
15.0, 18.0;
16.0, 9.0;
11.0, 12.0;
12.0, 12.0;
16.0, 3.0;
17.0, 3.0;
10.0, 6.0;
5.0, 15.0;
6.0, 15.0;
16.0, 2.0;
17.0, 2.0;
1.0, 3.0;
2.0, 3.0;
17.0, 9.0;
16.0, 10.0;
1.0, 2.0;
2.0, 2.0;
6.0, 7.0;
10.0, 7.0;
11.0, 7.0;
5.0, 8.0;
6.0, 8.0;
5.0, 7.0;
5.0, 16.0;
6.0, 16.0;
14.0, 18.0;
17.0, 10.0;
11.0, 11.0;
12.0, 11.0;
11.0, 6.0;
14.0, 19.0;
15.0, 19.0;
And here is a needed output, where distance between points in a sublist is 1.0 (in both directions X and Y):
{1.0, 2.0; 2.0, 2.0; 1.0, 3.0; 2.0, 3.0}
{16.0, 2.0; 17.0, 2.0; 16.0, 3.0; 17.0, 3.0}
{10.0, 6.0; 11.0, 6.0; 10.0, 7.0; 11.0, 7.0}
{5.0, 7.0; 6.0, 7.0; 5.0, 8.0; 6.0, 8.0}
{16.0, 9.0; 17.0, 9.0; 16.0, 10.0; 17.0, 10.0}
{11.0, 11.0; 12.0, 11.0; 11.0, 12.0; 12.0, 12.0}
{5.0, 15.0; 6.0, 15.0; 5.0, 16.0; 6.0, 16.0}
{14.0, 18.0; 15.0, 18.0; 14.0, 19.0; 15.0, 19.0}
I’ve attached an image to visualize my question.
The language doesn’t matter - I just can’t start with the logic. If it’s important, I am working in C#.
Thank you in advance for any ideas!
Good news.
You have 3 options (in fact 4):
  1. The classic one is to Cluster your collection according to a distance filter (and maybe some more).That’s the recommended way to cut the mustard for similar matters - because Clustering is a paramount thing in engineering.
  2. An other is some sort of LINQ query (may be 100% cryptic if you are not familiar with queries).
  3. An other is to create a suitable Class that assigns a prox distance Property to each object - meaning creating a List named, say, classList - and then do a classic LINQ thingy:
    var query = classList. CroupBy (x => x.Dist).ToList();
  4. BUT … If your goal is to create random islands of points … well … all the above are just useless reverse engineering - there’s numerous other ways to do that.
Notify which C# you want
Hi @PeterFotiadis
Thank you very much for your tips!
Already the first one about clustering has helped!
Here is the needed tutorial, that solves a problem similar to mine:
K Means Clustering is NOT the way for that kind of stuff (for obvious reasons: you don’t know the N of clusters). That said Clustering - in general - is far away and above from the scope of KM.
See attached (is an Interview C# for my people in the practice - so has various obvious [and hidden] challenges for the brave).
Clusters_PtsByMinDistance_V1.gh (140.2 KB)
BTW: What are you after is called rnd pts collections with density spots. When I’ll be in the practice I’ll find a simple entry level thingy on that matter.
I think “Point Group” component is what you need.
point group python code.gh (7.2 KB)
If you like to try it with your own code, here is one simple example by python.
Thank you @PeterFotiadis
It is much closer to what I need :+1:
Thank you @11165 for the Python solution!
It should be also helpful :rocket:
Found a couple of minutes to add (Help C# to the left) another option (4). Meaning that you have 2 options in total (3, 4) where you don’t need at all any clustering - since the pts output is in a DataTree.
Clusters_PtsByMinDistance_V1A.gh (137.1 KB)
Option 4 demos:
One question, is there a reason why you used the Matrix class instead of a jagged array?
Not really other than I have lot’s of Matrix related Methods (for far more elaborated results - the internal ones, that is)
ah,ok!
Thanks for the answer Peter!
Given the opportunity here’s a challenge for you.
See this? Is a naive implementation of attractors in rnd pts. Why naive? Because pts [pull] overpass the attractor (kinda the Event Horizon in a black hole) and we’ve got bananas (but OK for artistic purposes): Plus the push mode is stupid as well.
But … well … we are not artists (in fact I hate contemporary art: just a product). So do the right thing: mastermind a way where the point never passes any pulling attractor (and solve the push option properly):
So … start from that and do the required mods (is the weighted sum pts problem):
RndPts_ProbDensity_V1.gh (126.5 KB)
