Closest points giving the furthest ones
Hi
I have two point clouds and would like to connect all the points from cloud 1 to the points of cloud 2, in pairs. I want somewhat random behaviour from the connecting lines (and non-vertical lines), so I am thinking of using not the closest point but for example the third closest point.
Now what surprises me is that I am connecting the points that look more like they would be the furthest ones, instead of the closest ones.
What silly mistake I got going on in here?
Thanks in advance!
ClosestPointsQuestion.gh (16.6 KB)
this connects each point of list A to its 3rd closest point of list B
ClosestPointsQuestion_Re.gh (21.2 KB)
BUT :slight_smile:
it does not connect all the points in list B because not all the points of list B are proper “3rd closest point to a point of list A”, which also means that in list B some points are the 3rd closest point of multiple points in list A
so you end up with several lines starting from different points in list A, and ending in the very same point in list B
Thanks
I got in similar situation with a bit of borrowed definition. Not quite what it should be. Trying now via Delanau Connectivity.
Edit:
Didn´t work, but with new vertical lines from the starting points of the existing lines I could get the angles, and with Similarity I can sort out the lines that have too big deviations to the angles I want.
ClosestPointsQuestion2.gh (19.1 KB)
