Hi A really simple one but I am struggling with a simple issue. I create 2 ellipses make a rail curve between them, but whatever I do the surface produced goes down from the lower ellipse then reverses and twist u to the top ellipse producing a weird shape. Rotating the ellipse 180 degrees and reversing the point does nothing. Really frustrating as should be simple!
Yeah, that’s a tough one to understand. Sweeps - especially 1 rail sweeps - try to turn the profile to keep a constant orientation relative to the rail. The result is that the large ellipses get twisted up as they go into the sharper bends of the rail.
A couple of possible workarounds:
Sweep2 and use the 2 ellipses as rails and the wiggly vertical profile as the profile.
Add a vertical line between the two ellipse “centers” and again use Sweep2 with the wiggly profile and the line as rails and the ellipses as profiles.
I’m not sure if they will get you the results you want, as there are a number of shapes that one might expect from these 3 input curves.
