Wrong surface with sweep 2 rails
I tried to create a surface by using sweep 2 rails. I tried to do the same thing by using loft too but I had the same problem as you can see from the image.
I think it is something easy to fix but I tried different solutions but nothing happened.
Thanks a lot,
Mariella
Flipping all the curves on the right side could be a solution. But nobody knows without a file:
https://discourse.mcneel.com/t/how-to-ask-effective-questions/50034/2
