ShrinkWrap Request for additional features to the command
“ShrinkWrap”
Request for additional features to the command.
_ShrinkWrap
please to the command
Add cutting object option. It works like jewelcad. and gives excellent results.
_ShrinkWrap
It’s a great command in its current form. However, having the cutting object or negative object option will make the command more beautiful. Please take it into consideration as it will be more useful.
automatic unify and subtract occur simultaneously.
and mybe we dont need anytimes mesh edit software…
:slight_smile:
i hope add this option to in shiringwrap
Boolean subtraction included in the shrinkwrap command would be really nice.
?? solution
you can use the new, improved mesh booleans in Rhino 8, they work particularly well on parts that have been shrinkwrapped-
They never used to work now they actually work quite well.
see this video-
and this one-
For example, I wanted to mark the cutters that drill stone holes in a ring as negative objects and use them simultaneously in the shrinkwrap operation. This will perfect the shrinkwrap command.
I watched videos .shrink wrap is a successfully command .
I only want support u and designers :slightly_smiling_face::wave::wave:
Yes cutters please!!!
Thanks, I’ve recorded the request here. RH-82988
I really write this from a user perspective - knowing this might be hard to implement especially from the performance aspect:
I would love to see the following related Features:
Voxel-Volume
set some initial closed Objects or a Boundingbox to limit the space the algorithm is applied to.
A sub-option would be to (yes/no) include this boundary in the final surface creation.
Allow creation of open surfaces, that are limited by this Voxel-Volume.
Seeds / 3d-Regions
I imagine those seeds as points (and objects that get sampled under the hood) that start the “solidification”.
Similar to a paint-bucket tool, or a magic wand for pixel selection.
Min / Max Thickness / Bridge-Distance
Minimum will ensure, that Holes of a certain diameter are not be followed - independent from the edge-length.
Maximum will consider Volumes as separate if the exceed this value.
example
Imagine a huge pointcloud of a scanned building.
With a limited Voxel-Volume and a Seed it should be possible to get a single room.
With the correct combination of above parameters it should be possible to get the wall mounted Waste-Water-Pipes - at least of a single room.
does this make sense ?
yes voxels :100: :face_holding_back_tears: :pray:t4:
