Shrink wrap causing programme crash MAC
Coming across a problem with shrink wrap where clicking preview or generating the shrinkwrap is causing the programme to crash and shut down completely. I remember it working before but now can’t get it to, anyone else experience this on Mac?
Hi Joshua, can you run Systeminfo in the Rhino command line and post the results? Not recalling seeing any similar reports recently. Thanks
Rhino 8 SR3 2023-12-12 (Rhino 8, 8.3.23346.14002, Git hash:master @ 3b8659a0557b596b2d172939093022d2b67fd2e1)
License type: Evaluation, build 2023-12-12
License details: Cloud Zoo
Expires on: 4675756-12-14
Apple macOS Version 13.6.2 (Build 22G320) (Physical RAM: 16Gb)
Mac Model Identifier: MacBookPro18,1
Language: en-GB (MacOS default)
.NET 7.0.0
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M1 Pro
Color LCD (1728 x 1117 @ 120.00Hz)
LG IPS FULLHD (1920 x 1080 @ 75.00Hz)
USB devices
Logitech: G502 HERO Gaming Mouse
Logitech: G203 LIGHTSYNC Gaming Mouse
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/usd/libIex.dylib
/usr/lib/usd/libHalf.dylib
/usr/lib/usd/libAlembic.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/usd/libosdCPU.dylib
/usr/lib/usd/libImath.dylib
/usr/lib/usd/libIlmThread.dylib
/usr/lib/usd/libIexMath.dylib
/usr/lib/usd/libtbb.dylib
/usr/lib/usd/libMaterialXCore.dylib
/usr/lib/usd/libMaterialXFormat.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/usr/lib/swift/libswiftExtensionFoundation.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftExtensionKit.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftMapKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.3.23346.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.3.23346.14002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.3.23346.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.3.23346.14002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.3.23346.14002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.3.23346.14002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.3.23346.14002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.3.23346.14002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.3.23346.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.3.23346.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.3.23346.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.3.23346.14002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.3.23346.14002
hmm, i’m on a similar system and not able to replicate on a simple example. Can you do a screenshot of your settings before you hit preview? Thanks
happens if I press preview or apply, have tried changing target edge length but does it at any value
Not able to replicate, although i’m on a slightly different MacOS (13.5.2)
Do you have a lot of customizations? If not lets run a Reset command and do the factory reset.
what will I lose after performing reset? is the a way to restore rhino to how I had it after ?
Here are details on the reset.
