Showing the Rhino Editor from AutoCAD
I’m working on an AutoCAD plugin that uses Rhino.Inside for creating/modifying objects in an AutoCAD document. The end goal is to get the plugin to show the Rhino editor window so that these objects can be modified from Rhino/Grasshopper.
My question is, once Rhino.Inside is loaded into my plugin, can I just invoke the Rhino editor window? Do I need to actually start the Rhino process to do this?
Thanks.
Hi @jhenderson,
I’ll point you to the Rhino.Inside Revit open source code as it does exactly what you want to do and will server as a good model of how to do this.
Let me know if you find what you need or you need further assistance.
– Dale
