Hi guys,
Does anybody have a starting example to use RhinoInside for SolidWorks?
Any info is appreciated.
Thanks,
Dmitriy
Hi guys,
Thanks,
Dmitriy
Can you explain what you mean?
The project is open source. So, if anyone has access to the Solidworks C# SDK, then a Rhino.Inside project could be attempted. It would be interesting to see if it worked.
Can you explain what it is? and how to set it up?
Hi Zale_orcid, thanks for your interest.
The examples for Rhino.Inside can be found here rhino-developer-samples/rhino.inside at 7 · mcneel/rhino-developer-samples · GitHub
The Rhino.Inside® technology allows Rhino and Grasshopper to be embedded within other products. It may be possible to:
