Is there anyway that to show which layer the selected object belongs to when I select the objet?
Thanks a lot,
Aras
Thanks a lot,
Aras
one way:
or:
Hi Aras - Yes and no - you can do this from the ‘Tools’ icon in the layer panel; in V8/WIP there is a HighlightObjectLayers command as well. Here is a script that does this in V7 - I recommand making an alias or button for convenience -
HighlightLayers.py (683 Bytes)
To use the Python script use RunPythonScript, or a macro:
_-RunPythonScript "Full path to py file inside double-quotes"
Can I piggyback this and ask if there’s already a one-click (context-click, etc) solution for selecting “all objects on same layer”?
(As opposed to Show Object Layer, and then Select Objects on Layer/Sublayers.)
