Hi McNeel
Would it be possible to make it optional to also show the seam for closed curves, when you select a curve? I love that the control points show up when curves are selected, but almost just as often, I need to either rotate or use CrvSeam to adjust the seam. If I could avoid turning on ShowEnds (and turning it off again), that would be nice
TIA, Jakob
Yes, please!
