Shift glass plane of Curtain Wall?
Hello!
I can’t seem to find a parameter to shift the plane of the glass in a Curtain Wall.
To achieve something like this:
Is it possible?
Thanks a lot!
Eugen
Hi Eugen,
Yes, you need to open the curtain wall style editor, select the curtain wall style and, in the location tab, choose the alignment you prefer.
Regards,
Alfonso
Hello!
I get it now…
This parameter does not work in my case because the mullions have the same depth as the frame - which is a common case:
(found this after googling quickly)
When I make the mullions smaller or delete them at all, the glass can be aligned as you say.
However, deleting the mullions is not an option, because I need them.
I’d also suggest adding another offset parameter for the glass inside the mullions. A free value, though, not only exterior/center/interior.
Thank you!
I think you are right, an offset parameter for the glass might be useful for this kind of walls. This feature is already in our wishlist, so I will add your vote to it.
Regards,
Alfonso
A possible (clumsy) workaround for now is to create 2 Curtain Walls on top of each other, one with glass and hidden frame and mullions of the desired size, the other with visible frame and mullions of the same depth.
