unfortunately I ran into a quite uncomfortable situation here with my base surface, for my further project work I need a shell with an inner 10mm thickness, and I’ve been at it the last 2 days running into the same problems again and again. Whatever I do, cap the object and using shell command to get my desired thickness, or using the offsetsrf command to get it, there’s always a build up of unnecessary naked edges which I couldn’t remove even after hours of work.
Has anyone a work around of this commands, and can share some tricks?
