Shared vertices between 2 meshes
I’ve got two surfaces with control points in different places along the edge.
These are joined as a polysurface and meshed with these options
2
The result is this
But what I am trying to get is this
Has anyone got any suggestions as to how to achieve the result I’m looking for?
Hello - you might get away with AlignMeshVertices if you join the meshes into 1 and specify a large enough distance.
Hi Pascal,
Thank you - ooo that looks like a really useful command. Is there anyway of dealing with the open vertices that are left behind after running it…?
Hmm. not easily in V6 that I know of - that is, not without introducing triangles. In the V7 WIP there is InsertEdge that can get things lined up better with quads.
Introducing triangles isn’t a problem - how would you do it with tris?
Hi Hannah - If those are not actually gaps in the mesh then MatchMeshEdges may help; if they are holes, then FillMeshHole.
