ShapeDivers download help
Help with installing the full ShapeDiver plugin
I’m trying to install ShapeDiver for my Rhino (Rhino 7), but for some reason, even when I download it through Food4Rhino or via Rhino’s own PackageManager, it always installs a limited version that does not include essential inputs like SDInput Number, SDInput Integer, SDDisplayGeometry, and so on.
Any ideas?
Thank you very much,
Oren
Do you get errors when opening Rhino or Grasshopper? Have you made sure to uninstall all previous versions of the plugin installed manually (see warning section on this page: ShapeDiver plugin for Grasshopper)?
I simply get this form of ShapeDiver inputs, which I can’t work with. I made sure to uninstall all the previous versions…
There are no missing inputs in this list. You can simply use sliders, value lists, color swatches, etc… in order to define other types of inputs. You mention a missing SDDisplayGeometry component, but this components is not part of the “Inputs” category, but rather the “Outputs” one (the next one on the right).
Let me know if I am missing something.
Help with installing the full ShapeDiver plugin for Rhino 6
I’m trying to install ShapeDiver for my Rhino 6, but for some reason it was not download and install. even it not shows that download is start after clicking download and install button.
