Hello guys and ShapeDiver team,
my shapediver user is Armandof_90, this is my first time here. ![]()
I’m trying to embed a viewer into a website published using Google Sites, but I’m encountering a technical limitation that prevents it from working reliably.
I’ve seen in other threads that adding the domain sites.google.com to the whitelist should make the embed work, but in my case that domain has never worked.
What did work in the past was adding www.gstatic.com to the whitelist. This allowed the viewer to load correctly inside Google Sites for a while. However, this method no longer works either, likely due to changes in how Google serves published sites.
Currently, published Google Sites pages seem to be delivered from dynamic subdomains such as:
https://1504077899-atari-embeds.googleusercontent.com
The issue is that each time I publish or update the site, the subdomain changes, which triggers the following error:
Embedding not allowed for https://[new-number]-atari-embeds.googleusercontent.com
I’ve tried adding the exact subdomain (e.g., 1504077899-atari-embeds.googleusercontent.com) to the whitelist, and it works… until I publish the site again, and the viewer breaks due to the new domain.
I’ve also tried adding broader domains like googleusercontent.com or atari-embeds.googleusercontent.com, with and without wildcards (e.g., *.googleusercontent.com), but as far as I understand, the platform currently does not support wildcards at the beginning of the domain.
To try to stabilize the setup, I even purchased a custom domain and connected it properly to the Google Site, but not even whitelisting that custom domain has allowed the viewer to work reliably.
I’m relatively new to both ShapeDiver and Google Sites — so it’s very possible I’m overlooking a better approach. I’d really appreciate any advice or suggestions, especially something more stable than updating the whitelist manually every time.
My question is:
Is there any official or supported way to enable stable embedding from Google Sites, without having to manually update the whitelist every time the site is published?
Is there a way to dynamically allow these changing subdomains, or is wildcard or pattern-based whitelisting something you plan to support in the future?
Thank you for your time
. I’m working exclusively within the Google Sites ecosystem and would greatly appreciate any technical guidance to avoid switching platforms.
model name: v0.2.2.2E con appbuilding
current link to my web Wekaná studio - Maker mobili (made with sites.google.com)
Best regards,
Jesus
