I have a Grasshopper Definition (ShapeDiver_Example_Definition.gh (28.0 KB)
) that creates a parametric container with a lid and a 3d-nameplate. The picture below shows the resulting geoemetry with default values in Rhino.
When I upload my definition to ShapeDiver, it results in the following unexpected output:
The indices to select certain faces seem to differ from Rhino to ShapeDiver. When I change the index-values via the Shape Diver sliders, the base geoemetry is displayd correctly, but the text is still not shown as in the original definition:
I added a dropdown to rotate the text:
While the text direction is now correct, the text goes into the object instead of being placed on the surface, I can only change this by flipping the surface direction in Rhino.
You can find the unedited ShapeDiver version here: https://app.shapediver.com/m/sdexampledef-1
Summary:
- List Indices seem to differ from Rhino to ShapeDiver
- Surface directions in Rhino and the ShapeDiver output are not identical
Are there any erros or suspicious tools used in my definition that could cause these deviations?
I use Rhino 7 Version 7 SR10
(7.10.21244.1001, 2021-09-01)
Iām looking forward to your tips and suggestions
