Hi there,
I have a couple of Import Geometry and Import Bitmap components in my script. When I upload it to ShapeDiver, only one of the Import Geometry is showing. Is there a problem with my script?
Thank you!
Hi there,
Thank you!
Could you please share an example script to help me reproduce the issue?
My only guess at the moment is the following: components might not be showing as inputs in the ShapeDiver model if they are not driving any of the outputs of your definition (display geometry, file exports, etc…). In that case, they are ignored from the model and not shown in the control panel.
The Import Bitmap components feed into a Create glTF 2.0 material component and then I am assigning these materials through attributes before I show the geometry. Is there any way I could create materials with imported bitmaps and they show once I upload the model to ShapeDiver?
Please share an example script to help me reproduce the issue.
In this file, you are creating materials using the imported images but these materials are not connected to any display outputs, therefore they are ignored from the ShapeDiver model. If you connect a material to a display output, the Import component used for this material will show up in the online model.
