Hi! I have a very simple gh code that I have been trying to upload to shapediver. The upload is successful, but when I try to view the model (see link), no object is shown only the shapediver logo. What could be the issue causing this?
I can’t look at the file right now, but did you include the geometry display component and have something connected to it? I think it also needs a material to work.
Additional info:
If I turn on preview for component “Merge” containing all of the lines, they show up when uploaded on shapediver. However, I tried turning on preview for every component after this one, starting with “offset” and those do not show up on shapediver. Thus, I think there is some issue coming from flattening the merge component or from offsetting lines.
Thanks for the idea, but the mesh didn’t work either. I ended up going a different way and instead of offsetting the curves, I used the perp frame component and used the frame for the plane input in the rectangle component. Then lofted the rectangles and everything worked! I think the offset component seems to be the one causing some issues…
