I have a problem with ShapeDiver loading message and using ShapeDiver plugins. I have some old shapediver definition in which I used Kangaroo2.
In the meanwhile I installed Rhino7 tried to uplaod the same definition and receive message “Library Kangaroo2 Components 2.5.3 by Daniel Piker can not be used yet. The currently installed maximum version is 2.5.2. “
Than I go to List of supported third-party Grasshopper plugins page download and installed packagef supported plugins.
After restaring Rhino and Grasshopper I receive following error message (see attached txt fileGH_Load_Ex.txt (3.7 KB)
Additionally, Kangaroo2 still doesn’t work. ( IT seams that Rhino 7 have preinstalled Kangaroo 2.53?)
Hi @Bojan_T
I would recommend cleaning up your plugins library and re-installing the plugins you need, including the ShapeDiver plugin**.
The exact reason for this error seems to be that there is a missing or duplicate (with a different version) GrasshopperBitmap.dll somewhere which is causing loading errors in the updated plugins that depend on a specific version of it.
**The ShapeDiver installation should already contain this dll along with Squid. If you find an additional version of this in your libraries folder, please remove it.
