As you can see in the image:
I’ve selected the right transparent object and you can see it should show as a yellow object.
Though it shows his rendered settings and not his Shaded view ones.
Is there a settings I should know about to change the settings of this object?
Also I’ve tried to Match the settings with the ones that don’t “bug” but nothing changes.
P.S. New drawn objects are transparent. Why is the right one transparent?
Color & Material usage = Rendering material (got images imported on objects so they will be shown by this)
Backfase settings = use object’s color
Seems like the not transparent objects have something programmed in that in shaded view the object properties will be rendered and the other ones the material options. Is that possible?
