I’ve recently encountered a serious issue when using RhinoInside.Revit.
Whenever I open a Revit file and then launch Rhino (even without opening Grasshopper), Revit completely freezes the moment I try to delete or modify any elements connected to ductwork. The entire application becomes unresponsive and can only be closed forcibly.The issue only occurs with duct-related categories; other MEP categories are unaffected.
I tested this extensively with:
Multiple versions of Rhino 8 (all minor versions)
Multiple versions of RhinoInside.Revit
Multiple versions of Revit (including 2020)
The problem appears consistently across all combinations.
Interestingly, this issue does not occur when using Rhino 7 with RhinoInside.Revit — only Rhino 8 triggers the freeze. This makes me suspect the root cause may be related to some internal changes between Rhino 7 and Rhino 8.
Any insights, suggestions, or discussions from experts in this area would be greatly appreciated.
Thanks in advance!
