I have used wrap to convert .STL to surface. It has done it but produces several patches of individual surfaces. I am want to have one surface out of this. Is there a way that this can be achieved? I have attached the file. The idea is to import this into grasshopper and well imprint a pattern but the these surfaces are causing an issue. Sometimes they would merge and sometimes the edges are too far.
Hi Gaurav - Basically, if you really need a single surface, the answer is you cannot, as is - the object would need to be re-modeled, to be one surface, and it would not be easy… You canJoin the patches into a single polysurface, however.
Yeah I can join, I can also reduce the number of patches, but what happens is when I have joined them grasshopper does not recognize it a surface anymore. So remodeling is the only way? or is there another way? cause the I am new to rhino and grasshopper and still trying to figure the limitations of the software.
