Using SetPt command didn’t worked as I wanted or maybe it’s function works in other way.
Anyway, I’ve tried to align these wooden tiles by moving it in z axis. The problem is that the top surface of tiles have been extracted and left all alone while everything else went gone. Maybe I should use other command (if yes, which?) or maybe there is done something false in geometry of these tiles?
i assume your geometry has been exploded at some earlier stage, anyway that has nothing to do with setpt. for your case i would suggest using align instead.
Hi Tautvydas - If you are trying to set the top face of the objects to match the others, then make sure only the top faces are selected (Ctrl-Shift select) for SetPt.
