My Set Points command suddenly broke. Normally when I wrote the command and entered it was executing the command. Right now, the set points text is dissappered and when I enter it does not execute the command but ticks the axes.
did you already restart rhino and the computer / Operating System - Windows ?
did you backup your computer ?
did you update Operating system and Rhino to lastest version?
i won t be able to help, sorry.
it sounds like some of the mc neel people have to look at it. @pascal
post a screenshot of how the setpt interface looks.
try if the command is accessible as pure scripted version typing -_setPt (starting with -minus-) into the commandline.
what about other commands like _sweep1 _loft do they show the interace correct ?
there is a systeminfo (just type it in the commandline) command - you should post the results of this as well.
You were right. Obviously they have changed the sequence of work in the latest updates…
Sorry for bothering you. I have looked for the issue for days but did not really think typing spacebar in search box. Maybe we can keep the post but obviously enter works for finishing the command rather than spacebar with the latest release.
Let me ask that at least: Is there a way to change, adjust these? For example, can I use both spacebar and enter as a way to finish the command?
