Trying to create a sort of shrink wrap packaging as below.
Just noticed that during point editing of a surface, the SetPt command doesn’t work.
I can set scale=0 to the gumball so can flatten out but,
is this as specified? or perhaps there’s other options?
Right now, when I enter setpt, the command name set points does not show on dialog box and when I enter it does not execute the command. Do you think your method will help to solve this?
Command pop ups but normally when you enter, it sets the points to the selected axes, right? in my case, it turn on and of the axis selection but do not execute and set the points.
@Toshiaki_Takano how do you set your alias STPT? I don’t even what’s that unfortunately
