SetPt -command keyboard input not working in Rhino 7.9
SetPt command pops up a window where you can select the Cplane/world and which axis to use. I used to be able to change these settings with keyboard (and one letter of each setting was underlined in the pop up window). After our company updated Rhino to 7.9 (from 7.x) I cannot change these options with keyboard (mouse works) and the underlines are not visible anymore.
System info:
Rhino 7 SR9 2021-8-10 (Rhino 7, 7.9.21222.15001, Git hash:master @ 190335c3fb65efe86c302714a8959a7dadfe667b)
License type: Commercial, build 2021-08-10
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 32Gb)
Primary display: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 6-1-2021 (M-D-Y).
- Windows Main Display attached to adapter port #1
Primary OpenGL: NVIDIA Quadro T1000 (NVidia) Memory: 4GB, Driver date: 7-7-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 471.35
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-7-2021
Driver Version: 30.0.14.7135
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Users\JuTii\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\AI_RhinoPanel\3.0.1\AI_RhinoPanel.rhp “AI_RhinoPanel” 3.0.1.0
C:\Users\JuTii\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\Bullant\1.5.11.0\bullant.rhp “bullant” 1.5.11.0
C:\Users\JuTii\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\EleFront\4.2.2\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Users\JuTii\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\ggRhinoIFC\2.1.51.0\ggRhinoIFC.rhp “ggRhinoIFC” 2.1.51.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.9.21222.15001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.9.21222.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.9.21222.15001
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\PanelingTools (6caed836-bc06-4ebc-b1fd-e10886a0dc94)\2018.12.17.906\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 7\Plug-ins\import_ACAD.rhp “AutoCAD file import: import_ACAD”
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.9.21222.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.9.21222.15001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.9.21222.15001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.9.21222.15001
This was fixed in 7.10.
Regards
Jeremy
