Set Window Colors from RhinoCommon
Is it possible to set the all of these preferences via RhinoCommon, I have found some but not all of them?
Is any of the “Skinning” logic accessible from RhinoCommon? I’d love to be able to programmatically setup the color scheme / skin properties.
http://developer.rhino3d.com/api/RhinoCommon/html/T_Rhino_ApplicationSettings_AppearanceSettings.htm
–Mitch
Yes, I’m using that for some of the options. However Window Color isn’t in there.
How can I set the Window Color?
Doesn’t look like those settings are currently exposed in RhinoCommon. These are also Windows-only settings AFAICT, so that’s perhaps why…
–Mitch
@stevebaer @dale Any idea if you can put the remaining Window Color Settings from the Appearance options into RhinoCommon for us?
I think we can. :wink:
http://mcneel.myjetbrains.com/youtrack/issue/RH-33822
Thanks! Appreciate the help!
Looks like all but five of the colors, including “Window color N”, are ready available.
https://github.com/mcneel/rhino-developer-samples/blob/6/rhinocommon/cs/SampleCsCommands/SampleCsAppearanceColors.cs
Thank you again. I wondered what “PaintColor” was… :slight_smile:
Dale,
Do you know of any AppearanceSetting or PaintColor that will set the background color of the currently selected Properties/Layer/Display tab?
Hi Jason,
Run the WIP and pick Tools -> Options -> Advanced. Is Rhino.Options.UIPaintColors.TabBackground what you are looking for?
– Dale
I see what you were talking about. That is amazing stuff in there… I wish that whole table of values was accessible from RhinoCommon.
The TabBackground gets us close, there appears to also be a background color and a foreground color of white/black respectively that I cannot seem to change.
If you could find those values and expose them in the RhinoCommon, that would be fantastic!
Thank you in advance,
Jake
I’ll see to adding what I can to RhinoCommon for V6.
Thank you!
That would be nice. Trying to write a python script to change rhino UI colors to something darker. I think skins or themes would be a nice addition to v6. In the evening, with other programs in “night mode”, rhino is the one that is a bit hard on my eyes with its bright colors (which is fine during the day).
I second that!
And also the the setting for the white lines around the tabs (properties/layers/display) etc.
