In Autocad the user is able to set a dimension override so that everytime you draw a dimension, it automatically is set to the specified layer. Can you do this in V6?
Second, in paper space, is it possible to change the dim style to, say, larger than the dims in the model? (I’m sure this is easy)
A dimension style applied to a layer would be great, when using lots of layouts & annotations this would be very useful having the ability to apply different settings to different layers, or maybe it’s already possible ??
@brobes05 - you can set dimstyles ‘Model space scaling’, so you’d set the size as you like it for layouts and the apply a scale factor for model space.
This would be a big step in the right direction for those of us who are now using the Make2d with lots annotations in layouts, is there a way to put this on a wish list (or maybe it already is?)
