Set Current Renderer > Cycles?
I’ve used the cycles WIP before, and I had the option to use a modal’ed version of the renderer, using Render > Current Render options.
I now installed Rhino 6 (6.3.18090.471, 03/31/2018), and I can’t seem to find the option anymore, Cycles does not seem to show up as a render engine anymore.
Am I missing something here?
The renderer was WIP-only. Cycles is Raytraced viewport mode.
Thanks. Are there still options / workarounds available to do:
  • Batch rendering
  • Setting a resolution larger than your viewport?
Yes, you can use _ViewCaptureToFile and _ViewCaptureToClipboard, along with the dashed versions of those commands.
