Set a new view in Perspective without moving
I would like to make a button that simply re-orients to a top view, while in perspective mode and then allow me to continue in perspective mode from there. I have found 2 ways to get a top view:
Screenshot 2023-01-02 163600
The car top view that the green arrow is pointing to, changes to the top view, but also puts in ‘Top’ mode… so I can’t change the perspective angle… and when I push the perspective car, I am set to a default perspective angle… but I wanted to be just put in perspective mode without changing from the top view angle, so I can roll it around away from top myself away from a top view
The airplane top view that the red arrow is pointing to re-orients the perspective view to a top view and allows me to roll it around from there, but it moves me to the center of my cplane… which I do not want to happen… so I want it to act just like the airplane top view without moving my target or zoom.
What I want is a combination of these two buttons… I want to change my view exactly the same way that the little car top view does it, keeping my view, zoom, and target the same, but staying in perspective view like the airplane button mode so I can just take it from there in perspective mode.
It seems like I should be able to make a simple marco button that does the car button and then changes to perspective view without changing the zoom or target, but I haven’t figured out how to do that… is it possible to change back to perspective view without changing to the default perspective angle?
Hi James,
If you have a conveniently placed horizontal surface in your perspective view, you can use _OrientCameraToSrf to place the camera immediately above a chosen point on that surface which will have the effect you want. If you don’t have a suitable surface you could create one temporarily, otherwise I think a bit of programming will be needed.
HTH
Jeremy
Hi James -
'_SetView _Top -_ViewportProperties _Projection _Perspective _EnterEnd
currently on a mac without a mouse…(so i might be wrong with the key-combination)
there is a hot-key combination that allows you to release from plan-view:
ctrl + shift + RMB (right mouse button) should free the camera from looking down.
but projection will be parallel
the difference between the car icon and the plane icon:
car = world coordinates
plane = cplane - cordinates
EDIT:
another approach:
start rotating the view with RMB,
then press ctrl + shift
now the camera will snap to top-front-right… whatever is closest.
Thank You @pascal that works perfectly
@jeremy5 Thanks _OrientCameraToSrf would be helpful as well
@Tom_P Thanks for the ctrl + shift modifier suggestion, that is even better than a button to reset the view because most of the time I am already rotating it when I decide I want to start over from a top view.
I noticed that, but also
car = camera stays in place
plane = camera is reset to cplane center
