Can the GH_Param class read the input parameter?
using System;
using System.Collections.Generic;
using System.Drawing;
using Grasshopper.GUI.Canvas;
using Grasshopper.Kernel;
using Grasshopper.Kernel.Types;
using Rhino.Geometry;
namespace MySimpleIntegerParameter
public class MySimpleIntegerParameterComponent : GH_Param<GH_Integer>
public MySimpleIntegerParameterComponent()
: base(new GH_InstanceDescription("MySimpleIntegerParameter", "SimpleIntParam",
"TEST", "default"))
public double MedianValue = 0;
public double MeanValue = 0;
public override void CreateAttributes()
m_attributes = new MySimpleIntegerParameterAttributes(this);
protected override void RegisterInputParams(GH_Param<GH_Integer> pManager)
throw new NotImplementedException();
protected override System.Drawing.Bitmap Icon
get
return null;
public override Guid ComponentGuid
get { return new Guid("3fad705b-79b3-4984-9660-c1a1a38fd127"); }
public class MySimpleIntegerParameterAttributes : GH_Attributes<MySimpleIntegerParameterComponent>
public MySimpleIntegerParameterAttributes(MySimpleIntegerParameterComponent owner) : base(owner) { }
protected override void Layout()
// Compute the width of the NickName of the owner (plus some extra padding),
// then make sure we have at least 80 pixels.
int width = GH_FontServer.StringWidth(Owner.NickName, GH_FontServer.Standard);
width = Math.Max(width + 10, 80);
// The height of our object is always 60 pixels
int height = 60;
// Assign the width and height to the Bounds property.
// Also, make sure the Bounds are anchored to the Pivot
Bounds = new RectangleF(Pivot, new SizeF(width, height));
public override void ExpireLayout()
base.ExpireLayout();
// Destroy any data you have that becomes
// invalid when the layout expires.
protected override void Render(GH_Canvas canvas, Graphics graphics, GH_CanvasChannel channel)
// Render all the wires that connect the Owner to all its Sources.
if (channel == GH_CanvasChannel.Wires)
RenderIncomingWires(canvas.Painter, Owner.Sources, Owner.WireDisplay);
return;
// Render the parameter capsule and any additional text on top of it.
if (channel == GH_CanvasChannel.Objects)
// Define the default palette.
GH_Palette palette = GH_Palette.Normal;
// Adjust palette based on the Owner's worst case messaging level.
switch (Owner.RuntimeMessageLevel)
case GH_RuntimeMessageLevel.Warning:
palette = GH_Palette.Warning;
break;
case GH_RuntimeMessageLevel.Error:
palette = GH_Palette.Error;
break;
// Create a new Capsule without text or icon.
GH_Capsule capsule = GH_Capsule.CreateCapsule(Bounds, palette);
// Render the capsule using the current Selection, Locked and Hidden states.
// Integer parameters are always hidden since they cannot be drawn in the viewport.
capsule.Render(graphics, Selected, Owner.Locked, true);
// Always dispose of a GH_Capsule when you're done with it.
capsule.Dispose();
capsule = null;
// Now it's time to draw the text on top of the capsule.
// First we'll draw the Owner NickName using a standard font and a black brush.
// We'll also align the NickName in the center of the Bounds.
StringFormat format = new StringFormat();
format.Alignment = StringAlignment.Center;
format.LineAlignment = StringAlignment.Center;
format.Trimming = StringTrimming.EllipsisCharacter;
// Our entire capsule is 60 pixels high, and we'll draw
// three lines of text, each 20 pixels high.
RectangleF textRectangle = Bounds;
textRectangle.Height = 20;
// Draw the NickName in a Standard Grasshopper font.
graphics.DrawString(Owner.NickName, GH_FontServer.Standard, Brushes.Black, textRectangle, format);
// Now we need to draw the median and mean information.
// Adjust the formatting and the layout rectangle.
format.Alignment = StringAlignment.Near;
textRectangle.Inflate(-5, 0);
textRectangle.Y += 20;
graphics.DrawString(String.Format("Median: {0}", Owner.MedianValue),GH_FontServer.StandardItalic, Brushes.Black,
graphics.DrawString(String.Format("Mean: {0:0.00}", Owner.MeanValue),
// Always dispose of any GDI+ object that implement IDisposable.
format.Dispose();
MySimpleIntegerParameterComponent.cs (5.9 KB)
