_SelLayer problem
Has two problems for me. 1) the “make current level” option does not seem functional. 2) it is not possible to select a level using an object.
-Simon
Hi Simon - I see that the layer is not made current - but the Pick button does work to select an object and use its layer. ‘Set layer current’ is not in Windows Rhino - need to look into that one…
https://mcneel.myjetbrains.com/youtrack/issue/RH-55610
