I need to select the only the outer contour - the footprint of some buildings(which are in the same level) as curves-or surfaces and unify their regions afterwards, does anyone has any suggestion or Gh definition on how to do it?
I tried some ways, as simple as it seems it is not working .
How would you do it in Rhino? typically this is same way you script it as well. Any workflow is dependent on particular geometry you are working with..
Well basically I exploded the building geomtries and selected the lowest surface like in the attached definiton. I guess it workes for some simple geometries but not the a quarter.
