Lasso points also selects anything else as well inside lasso
V5
How does one use lasso points as it also selects anything else within the lasso !
Steve
I guess I’d use the selection filter - Filter pane in the status bar - to limit what gets selected. Note there is both Points (point objects) and Control Points in the Filter control.
Hi Pascal, how do I get a lasso type drawing selection using that filter ?
I am getting a rectangle type but my points are needing many selections in that way, almost as easy to select them one by one.
Steve
Filter : Points and/or control points checked, or whatever it is you want to select.
Lasso command.
