Hello all,
I have a large mesh, and I need to print a small segment of it.
I have figured out that I can position a cube at the segment I need to cut from my mesh, and use the Meshsplit command, but this leaves me with just the outside “walls” of the model (there is no fill and therefore no way to print it). These 3 sided meshes need to be closed, but I seem to be unable to even snap to the corners. I was trying to close them off and “rebuild” them as boxes so I could print them.
Is there an easier way to do this? Am I anywhere near being on the right track for removing portions of meshes and sending them to a printer without them being 3 sided “hollow” shells?
Thanks!
