Hi all,
Is it possible to select an individual surface from a polysurface or Brep? I am trying to select an individual surface from a polysurface to split using curves. But I cannot select individual surface using ObjectType.Surface, but can select the whole Brep if I use ObjectType.Brep
var go = new GetObject();
go.DisablePreSelect();
go.SetCommandPrompt("Select a surface");
go.BottomObjectPreference = true;
go.GeometryFilter = ObjectType.Surface;
go.Get();
if (go.CommandResult() != Result.Success)
return go.CommandResult();
var surface1_obj = go.Object(0);
Rhino.Geometry.Surface surface1 = surface1_obj.Surface();
var brep = surface1.ToBrep();
if (surface1 == null) return Result.Failure;
ObjRef[] crvRefs;
Result res = RhinoGet.GetMultipleObjects("Select splitting curves", false, ObjectType.Curve, out crvRefs);
if (res != Result.Success)
return res;
Curve[] splitCurves = crvRefs.Select(r => r.Curve()).ToArray();
foreach (BrepFace bf in brep.Faces)
Brep split = bf.Split(splitCurves, doc.ModelAbsoluteTolerance);
doc.Objects.AddBrep(split);
return Result.Success;
Hi @rajaa
Thank you for sending the solution. But unfortunately it is still not possible to select a surface out of a polysurface. After the prompt “Select a surface”, when I click a surface, the command fails. Only if I give the filter as polysurface or Brep, I am able to select the whole polysurface.
Hi @rajaa,
The code works when I put the ‘Selecting Curves’ part of the code in the beginning… I don’t know the reason for this. I have posted it below. The code is same, but Ive arranged it in a different way, and it works.
ObjRef[] crvRefs;
return res;
var go1 = new GetObject();
go1.DisablePreSelect();
go1.SetCommandPrompt("Select first surface");
go1.SubObjectSelect = true;
go1.GeometryFilter = ObjectType.Surface;
go1.Get();
if (go1.CommandResult() != Result.Success)
return go1.CommandResult();
Rhino.DocObjects.ObjRef objref = go1.Object(0);
var face = objref.Face();
if (null == face)
return Rhino.Commands.Result.Failure;
var brep = face.DuplicateFace(true);
if (null == brep)
