I tried selecting surfaces in polysurface but they return array not list. How do they return a list object?
import scriptcontext as sc
import Rhino
filter = Rhino.DocObjects.ObjectType.Surface
rc, obj_id = Rhino.Input.RhinoGet.GetMultipleObjects("Select first set of polysurfaces", False, filter)
print type(obj_id)
getsurfaces.3dm (187.6 KB)
diff-arch
(diff-arch)
June 29, 2021, 6:06am
2
Usually you can cast the C# type array to a Python list:
print type(list(obj_id))
i am looking for a solution to get list return objects. With the above method we only cast the data type.
dale
(Dale Fugier)
July 2, 2021, 4:09am
4
Hi @xiix.xoox ,
The simple “getters” like RhinoGet.GetMultipleObjects don’t allow for subobject selection. So you’ll need to use a GetObject object instead. Just set GetObject.SubObjectSelect to true.
– Dale
I try to change algorithm to get surfaces object but can’t select surfaces in polysurface ( The value input).
import Rhino
def GetSubObject():
go = Rhino.Input.Custom.GetObject()
go.SetCommandPrompt("Select objects")
go.SubObjectSelect = True
go.GetMultiple(1, 0)
if go.CommandResult()!=Rhino.Commands.Result.Success:
return go.CommandResult()
ids = [go.Object(i).ObjectId for i in range(go.ObjectCount)]
print ids
if __name__ == "__main__":
GetSubObject()
dale
(Dale Fugier)
July 7, 2021, 6:14pm
6
Hi @xiix.xoox ,
How about this?
import Rhino
def test_get_brep_face():
go.SetCommandPrompt("Select surfaces")
go.GeometryFilter = Rhino.DocObjects.ObjectType.Surface
if go.CommandResult()!= Rhino.Commands.Result.Success:
return
for objref in go.Objects():
print(objref.ObjectId)
print(objref.GeometryComponentIndex.ComponentIndexType)
print(objref.GeometryComponentIndex.Index)
– Dale
