Rhinoscriptsyntax polysurface filter also accepts single surfaces
If I run the following:
rs.GetObjects("Select a polysurface",rs.filter.polysurface)
it will also select a single surface object. The mechanism is clear, in selection.py we have:
Type 16 is a polysurface - but the filter accepts any brep, including a single face.
This is NOT the case with VB Rhinoscript, a type 16 excludes single faced breps.
Currently, if I want to filter correctly for a polysurface, I need to add a custom filter:
def real_ps_filt(rhino_object, geometry, component_index):
    if geometry.Faces.Count>1: return True
rs.GetObjects("Select a polysurface",rs.filter.polysurface,custom_filter=real_ps_filt)
Methinks this needs ‘adjustment’…
Hi Mitch,
Thanks for noticing that.
It’s been logged.
