Hi there,
New try today, I’d like to be able to pick several faces of different closed polysurfaces in my model.
I’ve tried to use the getobjects function with a custom_filter. But getobjects doesn’t allow subobjects selection and I need to extract from multiple polysurfaces.
For example, the command _MoveFace does it the way i’d like to do.
Would you know a workaround for this ?
Thanks for your help.
Baptiste
I’ve found a way in another thread :
import Rhino
import scriptcontext
class GetBrepFaces(Rhino.Input.Custom.GetObject):
def __init__(self):
self.GeometryFilter = Rhino.DocObjects.ObjectType.Surface
self.SubObjectSelect = True
def CustomGeometryFilter(self, rhObject, geoBase, ci):
print 'rhobj' , rhObject
print 'geoBase', geoBase
print 'ci', ci
if ci.ComponentIndexType == Rhino.Geometry.ComponentIndexType.BrepFace and rhObject != None:
print 'Face Idx: {}'.format(ci.Index)
return True
go = GetBrepFaces()
go.SetCommandPrompt('Select FACE')
go.GetMultiple(1,0)
