Baasab
August 26, 2024, 12:41pm
1
for many years I have in the bar on the underside ‘selected layer objects’ turned on so that I can see in which layer the slected item is:
Now, when nothing is selected there should be nothing in that box: (picture from Rh 7)
since a view weeks when nothing is selected, it says Varies:(Rh 8)
and many times when selected only one item it still says varies: (only one item selected)
Can this be fixed so it works properly?
thank you very much,
Albert
Japhy
(Japhy)
August 26, 2024, 12:55pm
2
Hi Albert, a quick test in our latest isn’t showing this behavior. Please run SystemInfo and post the result. Thanks
Baasab
August 26, 2024, 12:59pm
3
systeminfo.txt (2.8 KB)
I think I have the latest, and I checked with another user with the same results…
Japhy
(Japhy)
August 26, 2024, 1:57pm
4
Here’s my setting…
Do note is takes a half a second to populate after a change.
The video driver could use and update:
NVIDIA GeForce RTX 3070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 10-13-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 529.19
Another variable is the 3rd party plugin
C:\Users\AlbertBelger\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Corgi\0.6.3.0\Corgi.rhp "Corgi" 0.6.3.0
Baasab
August 26, 2024, 2:44pm
5
Hi I updated the videocard, removed corgi, waited some seconds after selecting an item but it doesn’t help.
Do you have other suggestions?
systeminfo 2.txt (2.5 KB)
