Object selection- highlight broken since update
Since the latest update Ive noticed that object selection has changed for the worse. If I want to select on object by clicking on it and there is a stack of parts to choose from , the little box will pop up to allow me to focus on the one I need. It used to be that if you rolled over each object in the list, the actual object on the screen would be highlighted allowing you to distinguish between each one and thus choose which one you want. That no longer happens, instead each object stays highlighted as the same. Very frustrating when you have 20 objects in the same box and cant find the one you need. Can this be rolled back to how it used to be please?
hi @Richard_Gamester pls run _SystemInfo in Rhino and post back the results
Rhino 8 SR9 2024-7-12 (Rhino 8, 8.9.24194.18121, Git hash:master @ 785b9fde79bb684d22aab317998f7195a8c27c14)
License type: Commercial, build 2024-07-12
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 128GB)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 4060 Ti (NVidia) Memory: 8GB, Driver date: 6-1-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 555.99
- Secondary monitor attached to adapter port #2
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-1-2024
Driver Version: 32.0.15.5599
Z-Buffer depth: 24 bits
Total Video Memory: 8188 MB
C:\ProgramData\McNeel\Rhinoceros\packages\8.0\Grasshopper_Gold_Tools\1.0\Grasshopper_Gold_Tools.rhp “Grasshopper_Gold_Tools” 1.0.0.0
C:\Program Files\Common Files\McNeel\Rhinoceros\8.0\Plug-ins\KeyShot12RhinoPlugin (78243fe3-17a0-4865-b713-88b4c224c48c)\1.3.0.0\KeyShot2023RhinoPlugin\Rhino 7\KeyShot2023RhinoPlugin.rhp “KeyShot12RhinoPlugin” 1.0.0.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.9.24194.18121
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.9.24194.18121
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.9.24194.18121
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.9.24194.18121
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.9.24194.18121
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.9.24194.18121
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.9.24194.18121
C:\Program Files\Rhino 8\Plug-ins\export_PDF.rhp “PDF Export” 8.9.24194.18121
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.9.24194.18121
Do you have customized your Rhino in any way?
If not then resetting to factory default is something worth to try.
In any case, if you can run the _Reset command and hit the ‘Save settings for support’ button and send the resulting file, I can have a look if it has to do with that before going that route.
Fixed. Thank you. I have no Idea how that changed. I havent made any changes to the settings.
Many thanks for your help
