Select objects in a region
Hi there,
Is there any script / macro / command sequence select objects automatically in a region and/or closed curve?
Thanks in advance
Hello- SelBoundary should do that. See also SelVolumeBox, SelVolumeSphere, SelVolumePipe, SelVolumeObject
Thank you for prompt answer… That’s fantastic !!
Last question
Any possibility to group the objects in a region and region itself??
once selected, use group, then make a named selection using NamedSelections
NamedSelections is such a handy tool, once I’d discovered this I’ve never stopped using it :+1:t3:
namedpositions is namedselections best friend. the two together are very cool.
Thank you… However i cannot use groupname in selboundary command… Here is the sample file attached…
The aim is;
After selecting blue polyline, it should automatically create a group including the objects inside the selected polyline…
:pray: :pray: :pray:
Group_Example.3dm (36.4 KB)
Hello- try a macro -
! _Selboundary _Pause _Group
Hello Pascal,
Thank you for your reply. However it does NOT include the selected boundary curve to that group…
Rg
